stripped oil drain plug
Loperamide
Post by Loperamide » Fri Apr 02, 2021 4:08 pm
Any ideas on how to take out a stripped oil drain plug (stripped inside allen hex and outer socket hex)
Re: stripped oil drain plug
Post by Leslie » Fri Apr 02, 2021 9:11 pm
Hammer a torx bit into the stripped Allen should grip enough to unscrew then or buy an oil sucker and take the oil out the dipstick
Post by henrym3 » Fri Apr 02, 2021 9:18 pm
That must be tight. If I understand the shape of the plug you describe then use a monkey wrench, failing that you’ll have to take off the sump but that will be messy with all the oil still in but you’d probably fair better on a bench
Post by Alan Gunn » Sat Apr 03, 2021 7:18 am
+ 1 on the torx bit method.
Post by marti » Sat Apr 03, 2021 9:57 am
Small pair of Stillson's will grab the hex and undo it no problem....
Loperamide
Post by Loperamide » Sat Apr 03, 2021 11:17 am
henrym3 wrote: Fri Apr 02, 2021 9:18 pm That must be tight. If I understand the shape of the plug you describe then use a monkey wrench, failing that you’ll have to take off the sump but that will be messy with all the oil still in but you’d probably fair better on a bench
https://www.amazon.co.uk/febi-bilstein- ... 381&sr=8-4
Its basically like the one in the link, but stripped both inside and outside. And there's not width to grab onto it on the outside where a socket wrench would go. I tried locking-jaw pliers but it kept slipping off.
Loperamide
Post by Loperamide » Sat Apr 03, 2021 11:20 am
marti wrote: Sat Apr 03, 2021 9:57 am Small pair of Stillson's will grab the hex and undo it no problem....
is that one of those pipe wrench's? There is not much space through the hole in the stiffening plate, and if locking-jaw pliers didn't work then there is no hope for a pipe wrench :D
Post by Greydog » Sat Apr 03, 2021 1:04 pm
You could take off the stiffening plate that would let you get Stilson's in
Or you could try another plumbers tool a Basin Wrench same locking action as the Stilson but designed to use in tight spaces.
Keep the Stilson handy to bash whoever butchered the plug in the first place, as it is destroyed in side and out they must be a determined butcher
Oh and get a new sump plug first would be my thoughts
Post by Alan Gunn » Sun Apr 04, 2021 5:56 am
Post by Greydog » Sun Apr 04, 2021 7:37 am
How about a surface drive socket they are designed just for this eventuality ?
Or in desperation drill through the centre of the plug and once the oil has drained use a stud extractor to remove the plug drop the sump clean and refit with new plug.
Out of ideas now
