Page 2 of 2
Hello at last
Posted: Mon Jan 03, 2022 10:12 pm
by coops
I am yeah - very glad it wasn’t bad lacquer. I have a Das 6 v2 DA polisher. Very easy to use
Did a long drive in it this weekend. Found out:
- Bumpy on country lanes. Really bumpy.
- Vibration at about 60-65 upwards through the floor
- bounces forward and back when coming to a stop
Hello at last
Posted: Mon Jan 03, 2022 10:59 pm
Bad dampers maybe?
Rear prop centre bearing?
Dampers again?
Been looking for a DA myself but can’t name my mind up between as DAS 6 or the Meguiars one.
Hello at last
Posted: Tue Jan 04, 2022 6:49 am
by coops
Cheers - and dampers recommended? And are the non-sport ones any more comfortable than the sport?
Das 6 has been great for me..
Hello at last
Posted: Tue Jan 04, 2022 9:49 am
Never played with the shocks on any X car. Others in here may have. Pinging Raj a PM might give you pointers as he replaced the air suspension on his E53 with coil overs. The thread will be on here somewhere, but a PM May get you a more succinct response. Sport shocks are normally ‘firmer’. Sachs are avail from Carparts4less at around £130 each (front) and £95 (rear). Bilstein are an option (and more expensive). If you have deeper pockets then Ohlins. Those are silly money though I expect. You’ll need spring compressors and tools to change the shocks as they’re coil overs front and rear.
It was only a suggestion that it might be dampers/shocks. I know the way it used to be done was to push down on each corner and see how many ‘bounces’ were there when you let go. If I remember it right, it should be ‘down, up, stop’ - as in that’s what the car does. If it ‘jiggled’ then the shock was suspect. Just getting a corner compressed may be a challenge all it’s own on these cars! :cry:
