Timing belt
PaulSanders
Timing belt
Post by PaulSanders » Wed May 11, 2022 5:51 pm
Garage has told me that the timing belt has possibly jumped. No symptoms just wouldnt start. Any advice?
Timing belt
Post by X5Sport » Wed May 11, 2022 6:03 pm
EDIT - just seen your other post. All the BMWs I know of have timing chains. In a diesel that’s often fatal because the piston can strike the valves as there isn’t much room in the head. Have they run diagnostics, or do you have the car unseen by a garage? Chains don’t tend to jump, they tend to snap and the engine would sound odd when cranking due to compression not being right. Jumping generally only happens if the tensioner fails and that can be heard as the engine starts rattling.
There are a number of issues with fuel or engine electrics that can cause a no-start. Any warning messages? If it’s a non-BMW garage then they need to run full diagnostics to track the issue down. Getting to the timing chain won’t be cheap. If it has slipped/snapped expect serious repair bills unless you have been really lucky with where everything stopped.
Timing belt
Post by Leslie » Wed May 11, 2022 8:47 pm
Likely a chain on the 2 litre and they are famous for stretching and breaking tensioners often before 100k was it rattling before?
Codes would help tell if its a timing issue as the chain is possibly at the back of the engine and hard to access. Without gearbox or engine removal
Cylinder Head will need to come off as valves are quite likely will be bent although sometimes just rockers are broken.
PaulSanders
Timing belt
Post by PaulSanders » Wed May 11, 2022 9:10 pm
No engine rattling or symptoms before it failed to start. No warning messages.
The garage are going to try and replace the sensor first.
PaulSanders
Timing belt
Post by PaulSanders » Wed May 11, 2022 9:12 pm
The engine turned over when I pushed the stop/start button. Just didn't start.
PaulSanders
Timing belt
Post by PaulSanders » Wed May 11, 2022 9:16 pm
The engine is an N47 engine. I have read on the internet these engines had timing belt issues.
Timing belt
Post by Alan Gunn » Thu May 12, 2022 6:17 am
They have a chain not a belt.
Yes the N47 does have the chain problem but the engine would rattle before it snapped.
A fault code scan before replacing any parts is recommended every time.
Timing belt
Post by StuBeeDoo » Thu May 12, 2022 8:21 pm
If, as you say, it drove fine but wouldn't start next time you wanted to use it my money's on the crankshaft sensor.
