Hi all,
Looking to change front discs and pads on F15 X5.
Realoem lists a 332mm and a 348mm disc on my VIN and refers to the 348 as part of the M performance power kit.
As I have the M sport package, will I have the 348mm discs?
Is the 332mm for China only or am I getting that round my neck?
Front disc size
Front disc size
M performance likely to have been a very expensive option you don't have, only sure way is to measure a disc
Front disc size
I believe M Performance and M sport are different packages M sport is the norm for most vehicles afaik
Front disc size
Which engine version? the 30d has smaller 332mm as standard with the 40d having 348mm fitted as standard. For the 30d it’s only the M Performance kit as you say that comes with 348x30mm and that kit was expensive (still is!) at build. If you use a VIN Decoder it should tell you if anything like that was in the car when built.
Measurement is the simplest course of action
