Battery Suggestion?
Battery Suggestion?
I am looking for a new battery for 2004 BMW X5 4.4I 5-Speed. What is the best option of a maintenance-free lithium battery for my car, the more power the better.
Battery Suggestion?
You need to check whether lithium is appropriate as the charging characteristics are different and the E53 doesn’t have a battery management system such as was fitted to the E70 and later models.
The OEM battery is (or should be) an AGM type.
I’ve used both Exide and Yuasa on my BMWs with good results. A good supplier is Tayna Batteries as used by members on here.
Battery Suggestion?
Have a look at Tayna batteries.
Put your reg number in then you can see what options and type.
Best prices i think as well and next day delivery well every time i have had that.
Battery Suggestion?
Sure, I will check. ThanksX5Sport wrote: Sun Jun 30, 2024 2:12 pm You need to check whether lithium is appropriate as the charging characteristics are different and the E53 doesn’t have a battery management system such as was fitted to the E70 and later models.
Battery Suggestion?
A couple of my friends have also recommended Tayna and this is my first option at the moment. ThanksAlan Gunn wrote: Mon Jul 01, 2024 4:48 am Have a look at Tayna batteries.
Battery Suggestion?
What are Yuasa like? After a new battery for my 2005 3.0D.X5Sport wrote: Sun Jun 30, 2024 2:12 pm You need to check whether lithium is appropriate as the charging characteristics are different and the E53 doesn’t have a battery management system such as was fitted to the E70 and later models.
2005 E53 X5 3.0D SE
Battery Suggestion?
I changed the one in my X6 a few weeks ago. Lasted 6 years and was just starting to show its age. Replaced like for like.
