More questions on the budget X5 search
Post by sapphireblack » Sat Mar 15, 2025 9:39 am
Three remote keys with this particular car but since battery changes, none will talk to the car? So the issue is obviously with the car.
Anyone any pointers on what to check/look for. Battery disconnect maybe?
Post by X5Sport » Sat Mar 15, 2025 3:14 pm
The keys should be able to be re-synced. A 30-minute disconnect might solve it. I have only experienced that on the E53 and it took a couple of minutes to re-sync them.
The E70 needs to use the dealer software system apparently. If the battery reset doesn’t work, then it’s a dealer visit.
Post by Leslie » Sat Mar 15, 2025 5:51 pm
Does it have comfort access ? as the keys are usually rechargeable and the batteries don't need changing .
Post by X5Sport » Sat Mar 15, 2025 6:21 pm
Comfort access on mine needs the batteries changing after around 12 months. The non-CA versions recharge in the key slot. Did BMW change the system?
I did have some oddities when I changed the X6 battery a few weeks back, Disconnecting and reconnecting fixed it.
