Intermittent satnav issue
Cookieuk
Post by Cookieuk » Tue Jun 21, 2011 10:38 pm
I get intermittent issue with my satnav.
Some days i will get into the car and the tmc on the monitor is red, and if i go into the navigation option it says something about inserting the dvd.
Other times it works absolutley fine.
Anyone else have/had this problem?
Sanj
Re: Intermittent satnav issue
Post by Sanj » Tue Jun 21, 2011 11:41 pm
Is the disc OEM? Or a copy?
Cookieuk
Post by Cookieuk » Sat Jun 25, 2011 3:28 pm
Its one from eurosatnav
pvr
Post by pvr » Sat Jun 25, 2011 5:08 pm
Copies are known to cause issues. Try the oem for a bit.
Cookieuk
Post by Cookieuk » Fri Jul 01, 2011 4:57 pm
Cheers, I had a little search for the original DVD and cant find it anywhere!
I have had a look on fleabay but not sure which one to get. Any suggestions? 53 plate pre facelift.
Post by X5Sport » Fri Jul 01, 2011 5:46 pm
I think you can only buy the OEM DVDs from a BMW Dealer. They're around the £175 to £200 mark.
Check whether there are any issues with Classic FM in your area as they carry the TMC data. No Classic FM means no TMC. I had issues a few years back when there was some engineering work underway and the local tranmitter was on low power. The car kept losing the signal and the TMC flag went red.
