Page 1 of 2
Faulty parking sensor
Posted: Sat Aug 21, 2010 5:29 pm
by Rick
Hi all,i have a problem with the parking sensors,when the engine is started wether i select Drive or Reverse the sensors bleep constantly without any obstacles in front or behind,i have to turn the alarm off using the parking button.Any will be much appreciated.
many Thanks Rick
Re: Faulty parking sensor
Posted: Sat Aug 21, 2010 5:54 pm
by Pewters
Put your ear right up close to every sensor and you should hear a clicking ...........obviously the one that qint clicking is the faulty one
![Wink ;)](./images/smilies/wink.gif)
Posted: Sat Aug 21, 2010 5:58 pm
by pvr
And pray it is an accessible one ...
Posted: Sat Aug 21, 2010 6:07 pm
by x555
Fingers crossed for you it's one of the rears.
Mine have been playing up recently aswell constant tone some times and perfect at other times
![Evil or Very Mad :evil:](./images/smilies/devil.gif)
i'm guessing that it's moisture in one of them
![Rolling Eyes :roll:](./images/smilies/rolleyes.gif)
I did the click test the other day and they were all clicking
![Confused :-?](./images/smilies/unsure.gif)
unlike before when i changed the front one and fixed them fine.......for a while at least
Posted: Sat Aug 21, 2010 6:09 pm
by Rick
Thanks for replies,as soon as ignition is switched on even without engine running the sensors are sounding constantly as if the x is parked right against something,its the same even if i am driving along.It is hard to pinpoint which sensor it is because os the constant noise
![Mad :x](./images/smilies/angry.gif)
Posted: Sat Aug 21, 2010 6:14 pm
by x555
This may be a stupid question mate but are they all clean?? it doesn't take much for these flaming things to play up
Posted: Sat Aug 21, 2010 6:16 pm
by Rick
Yep all clean,im sure 1 sensor is shorting out but its difficult to find which 1 with the constant tone all the time
Cheers Rick
![Headbang :headbang:](./images/smilies/headbanger.gif)
Posted: Sat Aug 21, 2010 7:25 pm
by pvr
Close the door whilst listening outside?
Posted: Sat Aug 21, 2010 9:24 pm
by Rick
I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick
Posted: Sat Aug 21, 2010 10:32 pm
by Sanj
Nope, bumper off jobbie BUT x555 has done How To for us on removing that front bumper. And the sensor should come in at £25 from eBay rather than the £80ish from the $tealers!
And it is different to all the others (front corner ones are different to the other six). These two are angled...
Posted: Sun Aug 22, 2010 9:37 am
by x555
[quote=""Rick""]I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick[/quote]
As Sanj says thats a bumper off job
that happens to be the very one that i replaced on mine a while back due to water/moisture gettin in.The bumper has to come off as it is encased in the steel of the bumper and you can't get your hand up to it.
Posted: Sun Aug 22, 2010 11:34 am
by Rick
[quote=""x555""][quote=""Rick""]I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick[/quote]
that happens to be the very one that i replaced on mine a while back due to water/moisture gettin in.The bumper has to come off as it is encased in the steel of the bumper and you can't get your hand up to it.[/quote]
Have looked on ebay but can only find straight sensors and not the angled ones for the corners,any ideas where i can get 1,also i cant find the part number.
Cheers Rick
Posted: Sun Aug 22, 2010 11:47 am
by x555
Here ya go.....no 12
http://www.realoem.com/bmw/showparts.do ... g=66&fg=05
Just washed mine and thought i would look at the pdc after this thread and got a constant tone but all sensors were ticking
one of the fronts did seem a little weaker thab the others so it could be that sucker
Posted: Sun Aug 22, 2010 11:55 am
by x555
Here's the type your after
http://cgi.ebay.co.uk/BMW-ORIGINAL-PDC- ... arParts_SM
but you would have to email the seller to check the code.
It doesn't necessarily have to be the same code to work AFAIK.Mine wasn't the same part no when i replaced mine but don't quote me on that as i wouldn't want you to get the wrong one.
Posted: Sun Aug 22, 2010 3:11 pm
by Pewters
Mine have been faulty for some time but its getting to me now...............i'll get Sanj on them soon
