Rear door handle removal?
JF1980
Post by JF1980 » Mon Aug 29, 2011 7:54 pm
Hi,
One of my rear door handles broke back in May - the retaining lugs on the front pin sheared off. I brought a primed replacement and have finally pained and clear coated it. Now I need to replace it, does anyone know how I remove and replace?
http://www.realoem.com/bmw/showparts.do ... g=51&fg=12
Part 10 is the piece I'm replacing. It looks like I need to remove part 9 and then it'll be easy. I'm guessing there will be a retaining bolt that should be removed from the inside - will it be a big job to get access?
Justin.
Current: 2012 E70 x40D Sport
Previous: 2004 E53 3.0D Sport
Sanj
Re: Rear door handle removal?
Post by Sanj » Mon Aug 29, 2011 8:30 pm
JF1980
Post by JF1980 » Wed Aug 31, 2011 2:00 pm
Thanks Sanj that may do (although mine is the rear door). Looks like I may be able to access via the small plastic oval bit, will have a poke around.
x555
Post by x555 » Wed Aug 31, 2011 5:03 pm
This thread may help a little aswell all be it for the front doors again....
viewtopic.php?f=8&t=1973&p=20709&hilit=door+handle#p20709
good luck.
JF1980
Post by JF1980 » Tue Sep 27, 2011 12:26 am
Well I finally got around to removing the access hatch on the back door (small oval black plastic cover). Not quite as simple as the front doors - there's no direct access to the rear section retaining bolt. It looks like I'll have to remove the interior panel but I'm a bit worried about disturbing the window mechanism; has anyone poked around in there before?
X MAN
Post by X MAN » Tue Sep 27, 2011 10:16 am
No need to remove the rear door panel . This should help .
I could be wrong but removal looks the same as front door handle as per Sanj`s door handle fix .
05 X5 3.0d
JF1980
Post by JF1980 » Tue Sep 27, 2011 10:45 am
You're my hero!
I'll report back at the weekend once done.
