foaming lance
foaming lance
Hi - I am looking to get a snow foam lance for my pressure washer but they all seem to come with different style fittings - karcher etc - my pressure washer is great and dont want to replace it but it came from Wickes so dont know what style the fittings are - can anyoen help ?
Smee
Smee
Re: foaming lance
Do you have a pic of the fixing? I have the lance but with karcher attachment.
Re: foaming lance
I had the same issue....two power washers from the same company - each with different fiitings.
Problem was quickly and easily solved by sending photos of the connector on the lance to Autobrite (
http://shop.autobritedirect.co.uk/index.asp)
I dealt with a chap called Mark Moss via : [email protected]
Next day I had two correctly supplied snow-foam attachments for my pressure washers. Perfect.
Hope that helps
Darren
PS I am in no way affiliated with these guys...
Hope that helps
Darren
Re: foaming lance
ok, thanks to all - turns out with was a lavor fitting and fits perfectly. I got a litre of valet pro snow foam and the instructions say "dilute to suit foam system"! - wtf ? By that do they mean the plus/minus adjustment on it ? It also says 25ml to 50ml per car - so i put that amount in the bottle tht comes with the lance and presumably the water goes straight in from the input to the ket washer - or do i need to put liquid in the bottle too?
smee
smee
Re: foaming lance
I did a 1:5 mixture, so filled up the bottle with 20% concentrate, then added hot water to it to fill it up .
I use about a third of the bottle for each application, so all in all works out ok.
With that ratio, I get the following result:
Re: foaming lance
This is the bottle:
Re: foaming lance
I usually put about an inch of snow foam in the bottle and fill up with warm water like pvr said.The plus and minus adjuster changes the spary of the foam ie thiner/thicker.The car should be fully covered in thick foam if it's done right.I then spray mine on with heated water aswell as i have a hot water presure washer
Re: foaming lance
great - thanks - wish I could connect mine to hot water but cant - oh well
Smee
Smee
Re: foaming lance
PVR i see you have the new foam lance.............how does it compare to the old one (assuming you had the old type) as my bottle has just broke.
Re: foaming lance
Never had the old one, got the brass one straight away (I assume you are referring to the breaking issue? )
Re: foaming lance
The pin on mine is loose and the neck of the bottle has cracked.........time for a new one me thinks
