Telestart T91 has problems
malc1950
Post by malc1950 » Thu Nov 17, 2011 8:06 pm
Three days ago i enabled my parking heater on the OBC and now it works ok, but i still have a problem with my telestart T91 , when i press the button on the remote it wont turn on and i dont get a signal back from the heater , but if i open the bonnet and press the remote near to the heater it will then start up and run for around 30sec or so but wont fire up then stops,strange as the heater works fine on the OBC, come on X555 what is the answer, :?
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights,  Rear view camera.
dirtymonkey29
Post by dirtymonkey29 » Thu Nov 17, 2011 9:22 pm
Batteries in remote? When I get mine working I want to get a gsm unit from www.danhag.de so I can activate/deactivate with a phone call.
malc1950
Re: Telestart T91 has problems
Post by malc1950 » Thu Nov 17, 2011 9:29 pm
Checked battery its ok thanks, gsm sounds good
dirtymonkey29
Post by dirtymonkey29 » Thu Nov 17, 2011 9:34 pm
Good thing about that gsm unit is you can get an option on it so you can wire into the alarm system so if it gets broke into it will ring or txt you
x555
Post by x555 » Fri Nov 18, 2011 6:35 pm
[quote=""malc1950""]Three days ago i enabled my parking heater on the OBC and now it works ok, but i still have a problem with my telestart T91 , when i press the button on the remote it wont turn on and i dont get a signal back from the heater , but if i open the bonnet and press the remote near to the heater it will then start up and run for around 30sec or so but wont fire up then stops,strange as the heater works fine on the OBC, come on X555 what is the answer, :?[/quote]
Sorry fella ....i can programme them to work but i haven't had to fix mine yet as it has worked from the start.......i shouldn't have said that should i :? :exitright:
Good luck
malc1950
Post by malc1950 » Sat Nov 19, 2011 8:24 am
Sound like my Telestart has a fault or not been installed correctly" by me" did you fit yours yourself ? Anyone know of a way to test it ?
x555
Post by x555 » Sat Nov 19, 2011 2:48 pm
[quote=""malc1950""]Sound like my Telestart has a fault or not been installed correctly" by me" did you fit yours yourself ? Anyone know of a way to test it ?[/quote]
I don't have the telestart mate ....i have the cheapo diy version :oops: provided by the main man on the forum....or is that old man :poke: ;) so can't help there fella.
malc1950
Post by malc1950 » Sat Nov 19, 2011 2:58 pm
Thanks x555 Hope someone can help me will keep on looking
Rusty
Post by Rusty » Sat Nov 19, 2011 11:18 pm
[quote=""malc1950""]Thanks x555 Hope someone can help me will keep on looking[/quote]
See, I was trying to help when I offered to buy your Telestart off you lol ;)
Runabout - E92 3 Series Coupe
malc1950
Post by malc1950 » Sun Nov 20, 2011 8:04 am
yes you did, but i wont give up well not yet !!
