check brake linings
shadrack
check brake linings
Post by shadrack » Sun Jan 15, 2012 9:41 pm
got this message up on the dash tonight but all the brake pads seem fine at least 10mm left on the all so a ((!)) symbol lit up, any ideas could it be a knackered / faulty pad sensor, thanks
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
thedweeb
Re: check brake linings
Post by thedweeb » Sun Jan 15, 2012 10:00 pm
Check the conections on the pad sensors,try unplugging then plugging them back in, they are front left and rear right.
gchristofi
Post by gchristofi » Sun Jan 15, 2012 10:04 pm
this came up for me last summer when i broke one of the sensor wires going over bumps. From memory, the 2 sensors are NSF and OSR.
shadrack
Post by shadrack » Sun Jan 15, 2012 10:05 pm
cheers will check it out
              2007 318d touring
              1964 vw beach buggy
gchristofi
Post by gchristofi » Sun Jan 15, 2012 10:07 pm
^^^^^^ doh, I should really fully read what you've written before repeating things!!^^^^^^^
dirtymonkey29
check brake linings
Post by dirtymonkey29 » Sun Jan 15, 2012 10:10 pm
Also the inner pad (the one you can't see... Typically!) usually wears faster. You'll probably need to get the wheel off for a proper look. As said before only one sensor front and one rear. Passenger side (near side) front, rear drivers side (off side)
shadrack
Post by shadrack » Sun Jan 15, 2012 10:25 pm
well tbh i know the front sensor is dodgy as the little clip bent funny last time i had the brakes apart the other month when i was having bother so going on this info im 99% sure itll be that
              2007 318d touring
              1964 vw beach buggy
dirtymonkey29
check brake linings
Post by dirtymonkey29 » Sun Jan 15, 2012 10:32 pm
Cheap fix then £10-£15 eurocarparts
shadrack
Post by shadrack » Sun Jan 22, 2012 7:01 pm
oooops checked them today and the inner pads have around 2mm on so a trip to motor factors tomora!! only thing is ive recently had trouble with the pedal pushing right to the floor and i got them bled up the other week so they were normal and now when i put new pads in right round it will be tight as hell!!
              2007 318d touring
              1964 vw beach buggy
shadrack
Post by shadrack » Mon Jan 23, 2012 9:02 pm
fitted new front pads and put the sensor back on as it came off, and anyway the lights still on, also when fitting i removed the cap off the resovoir for the brake fluid so as i pushed back the pistons(alot pads were on metal) and a small amount of fluid was pushed out is this ok?? also before i started the fluid was past the max level!
              2007 318d touring
              1964 vw beach buggy
dirtymonkey29
check brake linings
Post by dirtymonkey29 » Mon Jan 23, 2012 9:49 pm
Did you change the sensor too?
jaynana
Post by jaynana » Mon Jan 23, 2012 10:59 pm
[quote=""shadrack""]fitted new front pads and put the sensor back on as it came off, and anyway the lights still on, also when fitting i removed the cap off the resovoir for the brake fluid so as i pushed back the pistons(alot pads were on metal) and a small amount of fluid was pushed out is this ok?? also before i started the fluid was past the max level![/quote]
fluid was pushed out as in it overflowed? i think brake fluid is highly damaging to painted surfaces..
gchristofi
check brake linings
Post by gchristofi » Tue Jan 24, 2012 12:22 am
By the way, once you have a new sensor there is a reset procedure to turn the light off again. Something like leaving divers door open and turning key to pos 2 for 20 secs?
Search here and I'm sure it will come up.
dirtymonkey29
check brake linings
Post by dirtymonkey29 » Tue Jan 24, 2012 1:03 am
Divers door? Didn't know submarines had brake wear sensors too lol ;-)
gchristofi
check brake linings
Post by gchristofi » Tue Jan 24, 2012 7:40 am
Lol. @£&@£! iPhone.
