x6 wheels on e53
Posted: Sun Jan 22, 2012 6:43 pm
by syg9m
hi got the chance of a brand new set of X6 wheels will they fit the E53 , as I had a set of E70 alloys on with 20mm eibach spacers on ?
which model do I need to fit straight on without spacers ?
Re: x6 wheels on e53
Posted: Sun Jan 22, 2012 8:11 pm
by Sanj
They'll fit straight on - Raj has them on his.
Posted: Sun Jan 22, 2012 8:16 pm
Is there no problem with the bores then? I know the X6 rears have a smaller bore which causes issues on the E70, but I take it that isn't a problem on the E53?
Posted: Sun Jan 22, 2012 8:28 pm
by 4.8isDriver
i had X6 Y-spokes on mine, went straight on
Posted: Sun Jan 22, 2012 8:47 pm
by Raj
For the E53 you will need spigot rings to fit. Rears aren't a problem. Basically the X6 runs a slightly larger bore than the E53 up front but the same at the rear. Think from memory X6 is 74.1/72.6 bore front/rear, E70 is 74.1 all round and E53 is 72.6 all round.
I'm running X6 rimmage on my 4.8is.
Posted: Sun Jan 22, 2012 9:47 pm
by j2d
[quote=""Raj""]For the E53 you will need spigot rings to fit. Rears aren't a problem. Basically the X6 runs a slightly larger bore than the E53 up front but the same at the rear. Think from memory X6 is 74.1/72.6 bore front/rear, E70 is 74.1 all round and E53 is 72.6 all round.
I'm running X6 rimmage on my 4.8is.[/quote]
Would love to see some pics if u have any Raj?
Posted: Sun Jan 22, 2012 10:20 pm
by Raj
[quote=""j2d""]
Would love to see some pics if u have any Raj?[/quote]
Hi John,
only pic so far is this one:
Put them on then it went straight into Bal for ICE install.
Oh and not sure if you've had any luck with the LED bulbs but will check the sizes for you tomorrow with Hidesh @ CPD.
Posted: Fri Feb 03, 2012 9:29 pm
by syg9m
hi thanks for the feed back , bought the wheels but after looking on various websites the et on the rear wheels are et21 not et48 that have been advised as they are only 19" no 258 will they still fit ?
What size & et are the ones that you have fitted ?
Posted: Sat Feb 04, 2012 12:40 am
by Raj
[quote=""syg9m""]hi thanks for the feed back , bought the wheels but after looking on various websites the et on the rear wheels are et21 not et48 that have been advised as they are only 19" no 258 will they still fit ?
What size & et are the ones that you have fitted ?[/quote]
They will still fit even with et21. Mine are style 259's which are 11x20 et37. I initially ran a 20mm spacer with that too bringing it to et17.
Your style 258's are only 10x19 so an inch less in width but a more aggressive offset to give roughly the same outside position of the alloy as mine.
You'll be fine with them.
Posted: Sat Feb 04, 2012 12:56 pm
by syg9m
thankyou Raj I bought 2 sets if you know any body looking for some ?
x6 wheels on e53
Posted: Sat Feb 04, 2012 3:14 pm
by dirtymonkey29
What are they? how much? Where are you?
Posted: Sat Feb 04, 2012 9:47 pm
by j2d
[quote=""4.8isDriver""]i had X6 Y-spokes on mine, went straight on[/quote]
Any pics????
x6 wheels on e53
Posted: Sun Feb 05, 2012 4:39 pm
by dirtymonkey29
Posted: Sun Feb 05, 2012 7:42 pm
by 4.8isDriver
[quote=""j2d""][quote=""4.8isDriver""]i had X6 Y-spokes on mine, went straight on[/quote]
Any pics????[/quote]
Posted: Fri Feb 10, 2012 10:07 pm
by syg9m
Hi decided to keep the wheels but have some E70 style 213 alloys for sale tyres on the limit £500 & some copy 21" wheels bmw no tyres £500 ? if you send me your email address I will send photos .
