Running board retro fit - how hard, how much @ new and 2nd hand cost?
storminmike
Post by storminmike » Thu Jun 28, 2012 7:49 pm
My X5 doesn''t have running boards but the wife's does....boooo
Is this Hard, very hard, easy...easy peezy....to do or would there be loads and loads of bits wish one had never started?
What's the likley cost from new parts or 2nd hand?
Anyone actually done it themselves?
Re: Running board retro fit - how hard, how much @ new and 2nd hand cost?
Post by X5Sport » Thu Jun 28, 2012 10:09 pm
This post is over on Xoutpost and includes images of what needs doing.  It's few years old now but still relevant.  You do need to be mindful of differences for 20" wheels (which this one has) over 19" as you need arch flares.  Unfortunately the OEM instruction guide link on it doesn't work any more.. >:(
However this guide link does work..... :). It's a pre-facelift sample, but whether there is any difference I don't know.
There were discussions over there a while back about OEM v non-OEM and I think the concensus ended up with staying original as the quality was 'debatable' for those on fleebay etc.
Raj
Post by Raj » Thu Jun 28, 2012 10:52 pm
I don't think it will be a major job to do in all honesty. In terms of cost, not sure. May be worth calling a dealer to get the parts list for the retrofit (I'll ask Sytner Sutton Coldfield tomorrow if you want).
Once you have the parts list you can scour eBay and breakers for everything needed.
Sanj
Post by Sanj » Fri Jun 29, 2012 12:53 pm
Not a mission to do but you will need all four arches with the extended plastic to slide into the new side-steps.
You need to take all four arches off to get the old runners out (bolted in) and then you can put the new steps on and lastly slide the arches in and plastic rivet the lot.
Not a hard job - look at pewters wheel arch extension guide. That shows you how to get the arches off an then you can see how to get to the side-steps.
Just need to find some cheap ones going on ebay now!
storminmike
Post by storminmike » Fri Jun 29, 2012 7:59 pm
Thanks guys....looks like rivet pulling and a socket set, clear head and a dry day. There are a few more bits than I thought but I was expecting that the wheel arch bits needed to be replaced. I can see this going into quite a few £100s...
The parts are here but there are various options but I think I went with the normal option as I have 19" on sport
http://www.realoem.com/bmw/showparts.do ... g=51&fg=16
My guess is from realoem
dollar converted to £ +vat
1 Cover, wheel arch, front left 1 51718402333 $102.92 £63.53 £76.23
1 Cover, wheel arch, front right  1  1 51718402334 $102.92 £63.53 £76.23
2 Cover, footboard left 1 51718408677 $163.50 £100.92 £121.10
2 Cover, footboard right 1 51718408678 $163.50 £100.92 £121.10
3 Cover, footboard left 1 51718403077 $293.28 £181.03 £217.23
3 Cover, footboard right 1 51718403078 $293.28 £181.03 £217.23
4 LEFT DOOR SILL COVER 1 51718402335 $171.13 £105.63 £126.76
4 RIGHT DOOR SILL COVER 1 51718402336 $171.13 £105.63 £126.76
5 Cover, wheel arch, rear left 1 51718402337 $102.92 £63.53 £76.23
5 Cover, wheel arch, rear right 1 51718402338 $102.92 £63.53 £76.23
6 Expanding rivet L=15MM SCHWARZ ? 51111944537 $0.30 £0.19 £0.22
7 Blind rivet 12 51717002953 $0.78 £0.48 £0.58
8 Clip 4 51718267301 $0.61 £0.38 £0.45
9 Hex Bolt with washer M8X20-Z1 18 7119915093 $0.47 £0.29 £0.35
10 Naps ? 51717053464 $0.89 £0.55 £0.66
£1,237.37
OMG.....£1,237....surely that aint right...and that's not multiplying the clips
Post by X5Sport » Fri Jun 29, 2012 8:07 pm
Looks far too cheap........... :)
Remember that a 'kit' will be cheaper - at least I hope it will be!
storminmike
Post by storminmike » Fri Jun 29, 2012 8:09 pm
I think I've just changed my mnd
It would be cheaper to part out a wreck. Makes you appreciate getting the "spec" right when buying
me thinks a breaker would be an option but I'm sure they know the value of the parts
Post by X5Sport » Fri Jun 29, 2012 8:15 pm
If you want OEM then this is the BMW retrofit kit.  OK it's $900 bucks, but it's at least a bit cheaper.....and it's only for 19" wheels.
storminmike
Post by storminmike » Fri Jun 29, 2012 8:20 pm
Never thought about it in kit form
Hmmmm £660.70 approx....loadsa dosh though.....hmmmm
maybe this will come after a Hualigan or Parrot Mki 9200 in the next on the list to do
Thanks for the help though....anybody want an OEM Kidney :o
Sanj
Post by Sanj » Fri Jun 29, 2012 8:36 pm
eBay currently has all four arches for £160 total but you can get them for a lot less. Then just the steps and they go for less than £100...
Just save a search and you'll get emails daily.
storminmike
Post by storminmike » Fri Jun 29, 2012 8:44 pm
[quote="Sanj"]
Thanks for the tip....I see plenty of standard arches but I'll have a mooch
graemeX5
Post by graemeX5 » Sat Jun 30, 2012 6:48 am
Hi I posted a link a while ago as BMW were doing the arch kit for about 220 delivered instead of about 750 in parts
link below for BMW Genuine 20" Wheel Arch Extensions Retrofit Kit E53 X5 51710398336 with running boards
Genuine items~Direct from BMW~2 Year Warranty there is a kit with 335 at end not sure if for cars without running boards you may have to check OEM site
http://www.ebay.co.uk/itm/190659388391? ... 1423.l2649
It would be worth looking at their shop bmw direct store on ebay as may have offer on running boards as well Couldn't see it but poss worth email to them
Hth
