Water - Again!
Posted: Thu Jan 03, 2013 6:19 pm
by UrbanFlow
First off - Happy New Year all!
I’ve not been on here for some time now as my X5 has been performing impeccably.
Everything was tickety boo until Christmas Day and Boxing Day – when it lashed it down incessantly for two days.
Loading the boot up on the 27th something compelled me to look in the right cargo compartment in the boot. 1 inch of very clean water sitting in the bottom!
Now, it’s worth noting that when I bought the X two years ago it had 8 inches of snow on the top and I had found water in the bottom of this compartment.
In that instance I found that the wiring loom rubber at the top of the tailgate was hanging loose (circled green below). Refitted it and had no trouble with water again – or so I thought!
2 years water free and the rain this Christmas was clearly too much.
Water had collected in the base of the welled area again (inch deep) and the little carpeted shelf above it (Circled below) was sopping wet.
Water was also dripping slowly off the foam sound proofing marked in the picture below.
The wiring loom rubber is firmly in place - so I scoured the internet for other answers.
It seems that the rear sunroof drains can cause problems. They exit beside each of the wiring loom rubbers at the top of the hatch back (Circled red above) and can get blocked or even detach inside the headlining – eek!
Also, some forums mention water ingress from the rear light seals and the rear quarter panel window.
So my question is – has anyone else had this problem and managed to solve it??
Is the rear sunrood drain hose a nightmare to get to? Headlining pull?
I’ve run a hose all over the car, but nothing. It’s still dry now. Maybe that's it for the next two years!
Re: Water - Again!
Posted: Thu Jan 03, 2013 6:44 pm
by Raj
I had something similar last year and it was the rubber drain tubing where the petrol filler cap is that was cracked and was allowing water to leak in to the cubby area. May be worth a look but otherwise I would lean towards the rear tail light seals.
Also just because your X is performing impeccably doesn't you need to be a stranger... :)
Re: Water - Again!
Posted: Thu Jan 03, 2013 9:43 pm
by Jayx5
Mine was leaking on the near side and I changed the rear light seal(easy to do) it is slowly drying out so I think that sorted it :)
Re: Water - Again!
Posted: Fri Jan 04, 2013 9:18 am
by UrbanFlow
[quote="Raj"]
I know Raj, you're right. I hang my head in shame!
Not with the car today - missus has it - but is the pipe you talk about the water/overspill drain from inside the filler cap?
Re: Water - Again!
Posted: Fri Jan 04, 2013 9:20 am
by UrbanFlow
[quote="jayx5"]
Thanks Jay, I might change the seal anyway just to rule it out.
Re: Water - Again!
Posted: Fri Jan 04, 2013 1:41 pm
by Raj
[quote="UrbanFlow"]
[quote="Raj"]
Lol I'm only messing.
Yes the rubber hose inside filler cap but if it does look fine then the light seal is the other culprit.
Re: Water - Again!
Posted: Sat Jan 05, 2013 8:15 pm
by Jayx5
[quote="jayx5"]
[/quote]  nearside seal part number 6926773 £7.17 +vat.
Re: Water - Again!
Posted: Mon Jan 07, 2013 5:42 pm
by UrbanFlow
NIce one fella - I'm assuming the offside seal is the sane price.
