Front indicator bulbs .
bluex5
Post by bluex5 » Tue Nov 02, 2010 1:38 pm
Can anyone tell me how to change the front indicator bulbs in the headlight unit . They look a nightmare.
Paul . :headbang:
Sanj
Re: Front indicator bulbs .
Post by Sanj » Tue Nov 02, 2010 1:45 pm
Small hands useful but doable.
If that's not possible then mark where the headlight screws sit - two at the top two at the bottom, then loosen these and the whole cluster will come forward. Then you may have more room.
Bad design though. :thumbsdown:
bluex5
Post by bluex5 » Tue Nov 02, 2010 1:51 pm
Many thanks .I thought that may be the case . What a pain .
Sanj
Post by Sanj » Tue Nov 02, 2010 1:52 pm
If you can park the car up against a wall and see the beams - that will help.
You'll have two points of reference then.
AW8
Post by AW8 » Tue Nov 02, 2010 8:02 pm
Tbh maybe worth getting headlamp relaigned afterwards & if you move the headlamp.
I changed my offside freomt indicator a while back & spookily it was recently found to be out of alignment - despite me prior marking around the bolt fixture points.
pvr
Post by pvr » Tue Nov 02, 2010 8:15 pm
On facelift, I marked the screw positions with paint before undoing the headlights. Moved the lights forward until they hit the spray heads.
Enough space to get the bulb replaced then, unless you have carrott fingers like AW8 of course ...
AW8
Post by AW8 » Tue Nov 02, 2010 8:27 pm
......................sausages actually
pvr
Post by pvr » Tue Nov 02, 2010 8:46 pm
Point to note is that the dealer had to give me 3 lightbulbs before they got the right one.
Sanj
Post by Sanj » Tue Nov 02, 2010 9:08 pm
Agree you should get them properly aligned really, a friendly MOT place should be OK FOC...?
Raj
Post by Raj » Tue Nov 02, 2010 9:20 pm
[quote=""pvr""]Point to note is that the dealer had to give me 3 lightbulbs before they got the right one.[/quote]
That does not surprise me in the slightest...
