Front indicator bulbs .
Posted: Tue Nov 02, 2010 1:38 pm
by bluex5
Can anyone tell me how to change the front indicator bulbs in the headlight unit . They look a nightmare.
Paul .
Re: Front indicator bulbs .
Posted: Tue Nov 02, 2010 1:45 pm
by Sanj
Small hands useful but doable.
If that's not possible then mark where the headlight screws sit - two at the top two at the bottom, then loosen these and the whole cluster will come forward. Then you may have more room.
Bad design though.
Posted: Tue Nov 02, 2010 1:51 pm
by bluex5
Many thanks .I thought that may be the case . What a pain .
Posted: Tue Nov 02, 2010 1:52 pm
by Sanj
If you can park the car up against a wall and see the beams - that will help.
You'll have two points of reference then.
Posted: Tue Nov 02, 2010 8:02 pm
by AW8
Tbh maybe worth getting headlamp relaigned afterwards & if you move the headlamp.
I changed my offside freomt indicator a while back & spookily it was recently found to be out of alignment - despite me prior marking around the bolt fixture points.
Posted: Tue Nov 02, 2010 8:15 pm
by pvr
On facelift, I marked the screw positions with paint before undoing the headlights. Moved the lights forward until they hit the spray heads.
Enough space to get the bulb replaced then, unless you have carrott fingers like AW8 of course ...
Posted: Tue Nov 02, 2010 8:27 pm
by AW8
......................sausages actually
Posted: Tue Nov 02, 2010 8:46 pm
by pvr
Point to note is that the dealer had to give me 3 lightbulbs before they got the right one.
Posted: Tue Nov 02, 2010 9:08 pm
by Sanj
Agree you should get them properly aligned really, a friendly MOT place should be OK FOC...?
Posted: Tue Nov 02, 2010 9:20 pm
by Raj
[quote=""pvr""]Point to note is that the dealer had to give me 3 lightbulbs before they got the right one.[/quote]
That does not surprise me in the slightest...
