I have the dreaded Self Levelling Suspension Inactive warning on constantly now after replacing a faulty ride height sensor, it was intermittent prior to this.
The message has now been on for over a month now with no change to ride or handling so I know their are no leaks etc.....
I've read that it is possible to recode the Check System on start up to ignore certain warnings/errors.
I have checked through the functions using BMW 1.4.0 scanner and have confirmed there are no errors present but cannot find where to turn the warnings off?
I may eventually convert to coil overs but I really want to get rid of this error message.
Any help would be much appreciated.
Recode Check System on Start for SLS error
Dodge
Re: Recode Check System on Start for SLS error
Post by Raj » Mon Apr 29, 2013 7:46 am
I have gone to coilovers and coded out the initial start up heck control for the SLS however if it thinks there is a proper issue still it will still override this unfortunately. Even on mine I have had to leave the ride height sensors and control module in place due to the fact they also provide signals to the DSC, ABS, xenons levelling, etc so you can't remove them altogether without getting he whole thing coded out. This does mean when loaded up in the back for example the warning still pings up as it thinks there is a major issue and overrides the check control.
Raj
Post by Dodge » Mon Apr 29, 2013 7:28 pm
That sounds at least some part promising, even if it stays off for a month or two at a time, I don't load the car up that often so it shouldn't be an issue. The main question is how to do it, I've looked through the menus and even coded the alarm to beep on close and open, this confirms that the program works. I still cannot find an option to alter the check control function? Any help appreciated.
Dodge
Return to “General X5 Forum (E53 1st-gen, 2000-2006)”
Jump to
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
