BMW 1.4 scanner
BMW 1.4 scanner
Hi there.....Got my BMW scanner installed and working today and changed a few things. The problem ive got is the message cluster below the trip meter is now in french!!! Does anyone know what i have to do to get it back to english please.
X5 2004
BMW scanner 1.4
X5 2004
BMW scanner 1.4
Re: BMW 1.4 scanner
Do you have the speed camera alerts switched on now? I had this trouble about a month ago and that is what was doing it. When I bought the car it had an ebay special nav disc in it and I believe this is a common fault with copied sat nav discs. Try switching off the camera alerts.
Craig
Craig
2004 54 plate 4.8is X5 E53 facelift in Carbonswarz-metalic.
Re: BMW 1.4 scanner
Funny you should say that.....after i done my bits with the scanner, i decided to turn OFF speed camera alerts within the config menu......cos before they were ON
So would i have to turn mine ON again???
Thanks for the fast reply
Re: BMW 1.4 scanner
Thanks Lummox
Sorted !!!! And strange !!!! turned my alerts back ON again and its back to english !!!
So does this now mean i have to have alerts on all the time now to keep it to english.....cos when i had alerts on before it WAS in english.?
Re: BMW 1.4 scanner
I have the same problem but in reverse, if i switch on the camera alerts mine goes to french so it looks like you have them but don't want them and i haven't got them but would like them haha
Re: BMW 1.4 scanner
Do you mind me asking, where you got the scanner from ? Is it easy to use ?
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Re: BMW 1.4 scanner
Hi Ant.....got mine from http://www.ebay.co.uk/itm/310249608189? ... 1439.l2649
I would say its fairly easy to use. Ive changed a couple of things like audible sound when you lock car and most importantly...enabled Aux heating.
There are tons more things you can do, but i dont want to get too involved and mess something up, like the other day i was playing with it and all of a sudden i get the self leveling suspension error message come up. I was like omg what have i done ?? Anyway i done a rescan then took it for a drive and the message hasnt been back since. The same happened with the air bag light !!! There seem to be tons of threads about the scanner, so you can learn alot more off them than me. deffo worth having tho mate.
Re: BMW 1.4 scanner
Thank you for that
I am new to X5, I have Aux Vent but not being a diesel I dont 'think' I have heating
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Re: BMW 1.4 scanner
Its a rare, expensive option on the petrols, although the iS models, which you seem to have, were the more likely ones to have had all the options boxes ticked when ordered.
It would show up on the nav screen if you had the heating option, if not it just shows vent. And a quick look under the bonnet would confirm - the Webasto sits towards the rear of the engine compartment on the passenger side in my 4.8.
The scanners are readily available on ebay although I bought mine from http://www.bmcables.com/
X5 2005 Le Mans Blue 4.8is
Re: BMW 1.4 scanner
Shame i prob wont get to use my aux heating now until october or november time. :noexpression:
Re: BMW 1.4 scanner
I dont think (actually pretty sure) I dont have the webasto unit.
So does anyone know what use Aux Vent is ? I dont mean "its not much use", I mean what was BMW's idea for it to be included ?
Ta
Ta
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Re: BMW 1.4 scanner
Aux Vent allowed owners to run the fans a few minutes before going home time to cool the interior down on warm days. You set a start time and 'cool' air is pushed around the car to remove the possibly oven warm interior temp.
R
R
Re: BMW 1.4 scanner
That makes sense now, easy when you think about it
Heat for the winter, and air for the summer, Can it be included with the air-con to really cool the car, or is that asking too much ??
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Re: BMW 1.4 scanner
That needs the engine running to drive the AC compressor.
Re: BMW 1.4 scanner
The reason its not much use is because there is no real purpose in pushing hot air around with fans in a closed space anyway, it is not going to cool the interior down....... aux heating option makes sense, but the aux vent not really......
