unever rear hight
mickandlee
unever rear hight
Post by mickandlee » Sun Mar 02, 2014 7:10 pm
i have a bmw x5 30i 2003, the rear passenger side is slightly lower that the drivers side, i know about the airbag issue but i cant hear an air leak from the airbag, when i jack the car up then lower it back down the passenger side rises slightley then stops short of level with the driver side, any one got any idea, airbag ??? many thanks.
mickandlee
Re: unever rear hight
Post by mickandlee » Sun Mar 02, 2014 7:26 pm
could it be a suspension level sensor ?
Steamyrotter
Post by Steamyrotter » Sun Mar 02, 2014 10:24 pm
Could just need a sensor adjusted..
There is a setting in the body control ECU to offset the ride height against the "preferred" height to tune the levels of either side.
Unfortunately you need something like INPA to perform that.
