Horn just stopped working
How-To articles ONLY go here.
cooa99
Post by cooa99 » Tue May 13, 2014 3:06 pm
Hi all,
My horn has stopped working.
Pressed in anger when I was about to give someone a piece of my mind on the M20. It did a short beep and then went silent.
The horn fuse in the glovebox is not blown.
I have already done a search and come across posts http://xdrivers.co.uk/forum/https://xdrivers.co.uk/forum/viewtopic.php?t=8 and  http://xdrivers.co.uk/forum/https://xdrivers.co.uk/forum/viewtopic.php?t=8
explaining how to take the steering wheel bit off.
Is there something else I can check prior to meddling with the steering to further narrow down the culprit
cheers
Current Cars BMW 2005 X5 3.0d ;  Golf 2003 1.9 TDI for the High Miles Journey to work
Re: Horn just stopped working
Post by X5Sport » Tue May 13, 2014 3:10 pm
It might be the horn itself.
If you can, disconnect it and put a meter across the terminals and see if you get volts when the horn button is pressed.  At least you'll know which end to start at.
Y13HYA
Post by Y13HYA » Tue May 13, 2014 3:22 pm
Agreed as above. However its most likely the connections @ the steering wheel.
[align=center]2003 Estoril Blue X5 4.6iS - LPG Converted  www.xenon-upgrades.co.uk[/align]
cooa99
Post by cooa99 » Tue May 13, 2014 3:29 pm
Thanks guys,
what's the best  access route to those horns?. They are well tucked away in the engine bay
cooa99
Post by cooa99 » Sun Jul 20, 2014 12:26 pm
Ok,
I was able to remove the horns from the engine bay.
As advised, I tested the cables with a multimeter for current when horn pressed ... and was getting 12v current so I guess that implies that its the horns that are faulty. BMW charge a fortune for theses things + they sell them separately!
Post by Horizon » Sun Jul 20, 2014 1:26 pm
[quote="cooa99"]
Ok,
A trip to the breakers maybe, doesn't have to be a BMW horn either really
