anyone had this issue (2004 E53 3.0 D Auto
ok this is anew on one me and not seen anyone reporting similar as far as I can recall.
When I turn the steering wheel I get a squeaking sound. Really irritating. Worse when turning the vehicle to the left than the right. Sound like something is rubbing. Any ideas what could be causing this and what to lubricate ?
I've tried adjusting steering wheel position which improves it slightly but it not the wheel position that I want
Smee
Smee
Re: anyone had this issue (2004 E53 3.0 D Auto
Power steering fluid?
what makes you say that?
i had similar and turned out to be the track control arm,ball joint making the noise.
because it was knackered or does it make the noise because it needs lubricated (if it can be)?
it wasn't knocking or anything,just kinda squeak or rubbing like noise when i turned the wheel,i cut a small hole in the rubber boot that covers the ball joint and put some engine oil in it,result no noise so changed the whole arm.
[quote="Smeeagain"]
Smee
Mine does the same very faintly, turn on the wireless and you can't hear it , think it's probably the contacts between the steering wheel and the column.
Smee
[quote="TimX5"]
[quote="Smeeagain"]
Smee
wireless...........how old
[quote="Smeeagain"]
Smee
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
[quote="shadrack"]
[quote="TimX5"]
[quote="Smeeagain"]
Smee
I knew it would make someone chuckle lol , a wireless is more reliable than a x5
[quote="TimX5"]
[quote="Smeeagain"]
Smee
Wireless is new - I prefer to switch on the radiogram
.......and wait 10 minutes for the valves to warm up. That's why cars didn't have heater, the wireless did it all.
Ah, the days of 'The Light Programme'.........
- Steamyrotter
Will you lot get a room...
Or is it the whole wing in the retirement lodge????
>:D
>:D
Please note...
Please note...
Bog off or I'll hit you with my walking stick.......after I've got my Zimmer out of the car.... >:D
- Steamyrotter
You'll have to catch me first..
These mobility scooters can shift when they least want to...
Please note...
Please note...
