[quote=""Chompers""]Thats sounds a right PITA Stumpy
![Headbang :headbang:](./images/smilies/headbanger.gif)
I'm still confused as to why it would leak in the passenger compartment, is it the rear washer system that is causing this problem i.e. rear jet gets blocked with ice and builds up back pressure and blows at the weakest point? if so this is surely a design issue and as such should be taken up with a main dealer. You mention that your 'X' is out of warranty, by how long and what extended cover do you have? I would get to involved just yet until you have spoken to BMW.[/quote]
Warranty ran out last may, got extended warranty but that excludes coolant and fuel hoses - so pretty sure they would use the same argument for washer hoses. The pipe for the rear washers apparently runs along the side of the transmission tunnel on the drivers side under the carpet. It then get soaked up by the carpet.
