Towbar install
Towbar install
Hi ,I'm after some advice, im in the process of purchasing a 2013 30d msport and need to no how to remove the rear bumper , for the install of new towbar any advice would be great
Thanks ste
Thanks ste
Re: Towbar install
Pit your arm up behind the ehausts and push the reflectors out on each side, theres a 8mm bolt under each one, undo all the 8mm bolts around the bottom of the bumper about 6 i think, then for the trickyist bit remove the plastic rivets from inside the rear wheel arches enough to get the first bit of the plastic arch to come out above the bumper, theres another 8mm bolt under the arch at top of bumper, once all these are off give the bumper ends nearest the wheel a good sharp pull out wards this releases the clips (easier with one person each side) then go to drivers side and lower the bumper very carefully as you will have to unclip the pdc loom from the bumper.
Towbars pretty straight forward to fit, just remove the bumper re enforcement and replace with the towbar one,
When re fitting bumper be carfull to line all the tabs up under the tear tailgate
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
Re: Towbar install
Cheers for that is the dedicated electrics easy to do ,I've just sold my lemans x5 like your old one im in brotton and seen you have just sold your e70 hopefully get my new one In 2 weeks .im a sparky as well so should be straight forward,lemans one was easy to do .cheers ste
Re: Towbar install
[quote="Steve p"]
Yeh electrics arnt bad to do if your electrically minded, if you get stuck im probs 5 min from you!
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
Re: Towbar install
Thanks that would be great
Re: Towbar install
Have you got a towbar yet? Ive a brand new one for sale on here
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
Re: Towbar install
Thanks but ive just ordered the same as my old one a westfalia with detachable towball from PF Jones .
cheers ste
cheers ste
Re: Towbar install
[quote="Steve p"]
cheers ste
no problem, just pm me if you get stuck im only at easington and just removed full towbar and electrics a week ago
cheers ste
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
Re: Towbar install
You tube is your friend. I found a descriptive video of bumper removal on there. With the westfalia tow bar do you refit the bumper iron. With my witter I had to leave it off
Re: Towbar install
If you go to the PF Jones website, you can download the fitting instructions, and same for the wiring kits
Re: Towbar install
[quote="Manse73"]
thats good to know mine was a witter and the bumper iron is replaced
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
