Intermittent starting problem.
Al4693
Post by Al4693 » Tue Feb 07, 2023 11:44 pm
My E53 3.0d 2005 facelift has just started with a fault on starting. The engine starts but Immediately stops. This repeats for about half a dozen times, but then it will start with no issues. It happens mostly when warm, just after a short journey and when the car has been stopped a short time. The battery is fairly new, and fully charged, there are no dashboard warnings and no other problems.
Has anybody encountered such issues?
Post by Alan Gunn » Wed Feb 08, 2023 5:43 am
Any fault codes.
That is the first thing you need.
Post by Leslie » Wed Feb 08, 2023 6:32 pm
Warm starting is often caused by a cam sensor fault but you would need a code to confirm or rule out , its usually only a warm starting issue ,will fail to start several times ,long crank then after a couple of times run fine till the next time.
Al4693
Post by Al4693 » Wed Feb 08, 2023 7:08 pm
That's very helpful, thanks. My son has a tester which he loaned out but is recovering it this weekend so that we can run a test.
Post by X5Sport » Wed Feb 08, 2023 8:08 pm
If possible use one that can read the BMW codes out correctly rather than just list generic ‘P’ codes. It makes it a lot easier to decode and advise.. :) :)
Al4693
Post by Al4693 » Thu Feb 09, 2023 7:49 am
Thanks, I believe it is a dedicated bmw device.
Al4693
Post by Al4693 » Mon Feb 13, 2023 5:24 pm
Ran test on the Carly and it showed camshaft sensor issue. I've booked it into my local BMW indie.
Post by Leslie » Tue Feb 14, 2023 12:33 am
Happy days know on my 330d it was on the front of engine and could be swapped out in 5 mins only 1 bolt holds it in might not be as easy access on later engines mine was a 2001 m57 :thumbsup:
Al4693
Post by Al4693 » Wed Feb 15, 2023 6:56 pm
Great, thanks. Mine is a 2005 M57.
Post by Leslie » Thu Feb 16, 2023 5:37 am
Al4693 wrote: Wed Feb 15, 2023 6:56 pm Great, thanks. Mine is a 2005 M57.
Was close to oil filler cap on mine a single bolt held it in.
Post by X5Sport » Thu Feb 16, 2023 7:17 am
This help?
Numbers below are for the Hall Effect sensor and connector.
Al4693
Post by Al4693 » Thu Feb 16, 2023 8:09 am
That is very helpful. Thanks both!
