E70 ride height warning
Post by Greydog » Thu Jun 26, 2025 5:04 pm
OK
Just looking at realoem
This is the parts list that goes with the drawing attached yesterday the sensors are labelled Item 1 to the left and item 7 to the right. Take note of Item 7 Vehicles with self levelling suspension 2 off but all levelling sensor part Numbers are the same
I hope it makes more sense now
No. Description Supp. Qty From Up To Part Number Price Notes
i For vehicles with Xenon Light
S522A=Yes
01 Level sensor 1 37146853754
For vehicles with Chassis & suspens. setup "Adaptive Drive"
S2VAA=Yes
01 Level sensor 2 37146853754
02 Bracket, level sensor front 1 37146773135 $14.25
S2VAA=Yes
02 Bracket, level sensor front 2 37146773135 $14.25
03 Fillister-head screw M5X10-8.8-ZNNIV 4 07119904303 $0.25
S2VAA=Yes
03 Fillister-head screw M5X10-8.8-ZNNIV 8 07119904303 $0.25
04 Regulating rod 80.4MM 1 37146776549 $15.33
S2VAA=Yes
04 Regulating rod 80.4MM 2 37146776549 $15.33
05 Self-locking hex nut M6 ZNNIV SI 4 07147575163 $0.25
S2VAA=Yes
05 Self-locking hex nut M6 ZNNIV SI 8 07147575163 $0.25
06 Hex bolt M6X16-8.8-ZNS3 1 07119904371 $0.16
S2VAA=Yes
06 Hex bolt M6X16-8.8-ZNS3 2 07119904371 $0.16
07 Level sensor 1 37146853753
or
Self-levelling suspension
S2VAA=Yes
S220A=Yes
07 Level sensor 2 37146853753
08 Left ride height sensor bracket 1 37146871399
or
S2VAA=Yes
S220A=Yes
08 Right ride height sensor bracket 1 37146871400
09 Hex bolt M6X12-8.8-ZNS3 1 07119905827 $0.38
or
S2VAA=Yes
S220A=Yes
09 Hex bolt M6X12-8.8-ZNS3 2 07119905827 $0.38
10 Regulating rod 71,5MM 1 37146752797 $6.18
or
S2VAA=Yes
S220A=Yes
10 Regulating rod 71,5MM 2 37146752797 $6.18
11 Universal socket housing uncoded 6 POL. 1 61138383300 $3.47
only in conjunction with
-- Contact bushing MQS ELA with cable 0,35-0,5 MM² AG 3 61130056961
-- Dummy grommet MQS Ø=3,6 3 61138366249 $0.20
12 Universal socket housing uncoded 6 POL. 1 61138383300 $3.47
Post by Leslie » Thu Jun 26, 2025 5:43 pm
Id get a look under there first see if its the wiring is bodged or the actual sensor is faulty or the little link arms have come off.
Post by sapphireblack » Thu Jun 26, 2025 6:14 pm
The wiring on both is apparently bodged from a recent health check report.
And the plot thickens. Without doubting any input here i wondered what genuine parts might cost. That stirred the situation at the dealership somewhat, as my car was apparently showing as a US spec. OK, so we know they are built there, but the steering wheel is on the right side in my car, which they have had in the workshop only recently.
Anyway, after a hiatus, i just got this via email. It shows different part numbers per side, so i am even more confused.
We have finally found them! I had to pull in the parts manager from Tunbridge Wells too and he was stumped as well.
The part number you gave me is correct but I wanted to confirm that they are correct for your car.
37146853753 - £84.89 + vat
37146853754 - £78.37 + vat
Both are available to order 2 day lead time.
Post by sapphireblack » Thu Jun 26, 2025 7:52 pm
I wish i was more hands on. Looking back on the heath check report, it mentions bodged wiring as i mentioned above, it doesnt condemn the sensors.
Maybe i need a good wiring man more than new sensors! 🤔
Post by Leslie » Thu Jun 26, 2025 8:28 pm
The front left sensor is probably for xenons mine has adaptive xenons and has a left front sensor . Depending on whats actually wrong with the wiring a used plug with some wire to reattach is maybe the best way forward and get it soldered in.
looking at realoem 754 part is a front and 753 is a pair of rears , the left of which has a bracket possibly the right doesn't need a bracket , my car isnt at home to check as its broke at the minute :rofl: You can see number 2 is a front bracket and the operating arm is at right angles where the rear is parallel , that will likely be the only difference between a front and rear but they wont be interchangeable .See below
https://www.realoem.com/bmw/enUS/showpa ... 7146853753
Post by sapphireblack » Thu Jun 26, 2025 8:53 pm
I appreciate the continued guidance. I can't lift the rear end of the car on ramps as I don't possess any, and knees are no longer conducive to handling wheels on/off without some difficulty, if i can avoid it.
I know an auto electricians near enough to visit. They have a full lift and can get underneath it. I think I'll start there before buying any parts on spec. It could just need a wiring tidy up?
If ...753 is a paired set up even the dealership has got it wrong.
Post by Leslie » Thu Jun 26, 2025 8:59 pm
They probably assumed yours had xenons as most cars had :thumbsup: the 754 shows for adaptive drive and 753 for adaptive drive or self levelling suspension so its a bit confusing really :? but part 2 the bracket is shown for front and linked to 754 so I can only assume its the front sensor .
An auto electrician sounds like just the man for the job .
Post by sapphireblack » Fri Jun 27, 2025 8:18 am
Well the car does have air suspension but not very much else. Halogen headlights and manual folding door mirrors.
It is poverty spec for sure and a totally different animal to my E71.
From what is easily determined, the car was built March 2009 but it was only first registered September 1st 2009. Clearly, it's not a customer vehicle order.
Post by Leslie » Fri Jun 27, 2025 9:06 am
I have auto folding mirrors and given the width of it them are needed for parking , its definately poverty spec lol maybe a company purchase that had to be under a certain cost.
Post by X5Sport » Fri Jun 27, 2025 9:12 am
It might have been ordered just as the financial crash of 2008 happened, got cancelled and reduced to minimum spec. Dealer probably still had to take it.
Post by sapphireblack » Fri Jun 27, 2025 9:20 am
X5Sport wrote: Fri Jun 27, 2025 9:12 am It might have been ordered just as the financial crash of 2008 happened, got cancelled and reduced to minimum spec. Dealer probably still had to take it.
All plausible i don't doubt.
So the auto electricians i know actually declined to get involved its a BMW But they did refer me to an ex techie who i have spoken to and seems to know the issue.
I'm waiting on a call back to tell me when to bring it to him.
I don't regret buying this car just yet, but it ceased being a budget vehicle a while ago. It is still better suited to a life in Greece than the 'mint' E71 so ill keep cracking on for now.
