Hi guys
Anybody had any issues with the washer fluid tank leaking?
Mine must have some sort of leak from behind the tank and it keeps emptying the fluid!
I the impression it's only 2 bolts holding the tank in place and a quick removal should see if any pipes have come off?
Just thought I'd ask if anybody else has had the same?
Max
Washer Fluid Tank leaking?
Not had the same but yes, two bolts (10mm heads) and the tank is free.
Hope it is only a pipe or something simple. While the tank is out, it could be worth cleaning out the filters etc.
Hope that helps
Hope that helps
Runabout - E92 3 Series Coupe
Re: Washer Fluid Tank leaking?
This is the TIS for getting the washer tank out....
it could be coming out of the pumps themselves, I had this problem earlier this year. first on the front screen pump and then about 2 weeks later on the rear screen pump.
Phill
Phill
2003 X5 4.6is - Now dead
Thanks guys
I'll try and have a look tomorrow
X5 D Sport
some of my old toys gallery
hi - an old topic but I have this problem too in my e70 X5 - how easy is it to remove as the TIS link Is dead?
Thank you
S
Thank you
S
answered my own question but others might need in the future so:
http://workshop-manuals.com/bmw/x_serie ... sher_unit/
