Washer Fluid Tank leaking?
max
Post by max » Fri May 25, 2012 11:34 pm
Hi guys
Anybody had any issues with the washer fluid tank leaking?
Mine must have some sort of leak from behind the tank and it keeps emptying the fluid!
I the impression it's only 2 bolts holding the tank in place and a quick removal should see if any pipes have come off?
Just thought I'd ask if anybody else has had the same?
Max
Rusty
Post by Rusty » Sat May 26, 2012 12:28 am
Not had the same but yes, two bolts (10mm heads) and the tank is free.
Hope it is only a pipe or something simple. While the tank is out, it could be worth cleaning out the filters etc.
Hope that helps
Runabout - E92 3 Series Coupe
Re: Washer Fluid Tank leaking?
Post by X5Sport » Sat May 26, 2012 8:47 pm
This is the TIS for getting the washer tank out.... :)
phill
Post by phill » Sat May 26, 2012 9:02 pm
it could be coming out of the pumps themselves, I had this problem earlier this year. first on the front screen pump and then about 2 weeks later on the rear screen pump.
Phill
2003 SAAB 9-3t convertible 175bhp - current
2003 X5 4.6is - Now dead
max
Post by max » Sat May 26, 2012 10:15 pm
Thanks guys
I'll try and have a look tomorrow
splang
Post by splang » Sat Mar 19, 2016 2:00 pm
hi - an old topic but I have this problem too in my e70 X5 - how easy is it to remove as the TIS link Is dead?
Thank you
S
splang
Post by splang » Sat Mar 19, 2016 2:01 pm
answered my own question but others might need in the future so:
http://workshop-manuals.com/bmw/x_serie ... sher_unit/
