Why does it always take longer ......
storminmike
Re: Why does it always take longer ......
Post by storminmike » Wed Sep 19, 2012 8:14 pm
[quote="Sanj"]
No liquids lost, just fiddly.
Any blockage with carbon deposits will have some adverse affects on performance/efficiency.
I see 4 nuts possibly 2 of which hidden a bit?
a large hose -jubilee clip?
A solid pipe with a bend - not sure how attached
A small vacuum pipe?
that it?
Carb cleaner----Halfords?
Have already replaced the air filter and the oil separator ,,,which was foam....54 plate facelift
Sanj
Post by Sanj » Wed Sep 19, 2012 9:46 pm
In that case, this is a no-brainier for you. You'll cope with this without any issues.
Just watch the 2 nuts underneath, you can lose them easily into the depths of the engine bay!
Otherwise you've got it covered (do a quick search for x555's How To on the subject).
storminmike
Post by storminmike » Thu Sep 20, 2012 8:30 pm
[quote="Sanj"]
Cheers for that....somerimes in situations like this I might buy in a couple of nuts....just in case
pvr
Post by pvr » Thu Sep 20, 2012 8:42 pm
ah yes, X555 - ashame he has disappeared after he sold his X5. Mountain of knowledge there.
911 50th anniversary -
storminmike
Post by storminmike » Thu Sep 20, 2012 8:43 pm
additional
http://www.realoem.com/bmw/showparts.do ... g=11&fg=40
This diagram is interesting....am I right in sayint the pipework takes turbocharged air...passes it through the intercooler then via the EGR into the engine?
If so and the EGR is manky then that crud could have come through turbo or cooler...or am I wrong>?
Has anyone ever made the intercooler bigger (a faff I know) to get more power?
storminmike
Post by storminmike » Thu Sep 20, 2012 8:44 pm
[quote="pvr"]
well he could keep his hand in on mine if he wanted too :)
Post by X5Sport » Thu Sep 20, 2012 8:47 pm
You could try pm'ing him to see if he's still about...... :)
pvr
Post by pvr » Thu Sep 20, 2012 8:50 pm
Last active on July 18th though, which happens to be my birthday. The bugger never congratulated me  :))
storminmike
Post by storminmike » Thu Sep 20, 2012 8:56 pm
I'll be fine....after all I've just fitted new (EBAY) horns to the wifes X5 after one decided not to work....now that was an exercise in one handed car gynecology
seems there is a U shaped clamp that holds the side pipe on to the egr
storminmike
Post by storminmike » Thu Sep 20, 2012 8:57 pm
[quote="pvr"]
,,,,did you get a card from the queen
pvr
Post by pvr » Thu Sep 20, 2012 9:01 pm
No, Sanj did not send me a card either  :))
Sanj
Post by Sanj » Fri Sep 21, 2012 1:31 am
[quote="pvr"]
You can have a belated kiss at the meet. :o
Post by X5Sport » Fri Sep 21, 2012 1:03 pm
[quote="Sanj"]
[quote="pvr"]
That will have to be documented for posterity........... :camera: :camera: :-[
