Near Side Mirror (A mind of it's own)
dobbor1
Post by dobbor1 » Mon Feb 25, 2013 12:04 pm
Hi, my side mirror seems to be confused when I select reverse.  It can't decide sometime whether to angle down or not.  It's got to a point now where it moves up and down randomly like a mad man.  Are the motors easy to replace and are they costly?
Dobbo
Currently:  2011 E70 X5 40D M Sport Black Sapphire
Previously: 2006 E53 X5 30D Le Mans Blue Sport Edition
Don Coffey
Re: Near Side Mirror (A mind of it's own)
Post by Don Coffey » Mon Feb 25, 2013 12:09 pm
Is it a motor issue or switch issue.  I'm thinking switch as the motors still working. I assume you have tried flicking the mirror adjust switch back and forth to see if its as simple as that?
Don
Post by X5Sport » Mon Feb 25, 2013 12:33 pm
I had mine replaced under warranty because it was doing this.  It was very dirty inside they said and the switches were knackered.
The replacement mirror started doing it after a couple of years too but I found that cycling it a few times with the mirror switch made it behave for a little while.
dobbor1
Post by dobbor1 » Mon Feb 25, 2013 2:27 pm
It also has a barney when I push the memory button on the side of the drivers seat to try and bring it back up if it does finally drop down but then stays there when I flick out of reverse.
Sent from my GT-I9100 using Tapatalk 2
jaynana
Post by jaynana » Mon Feb 25, 2013 3:06 pm
the motors become sticky. remove the mirror outer and do a cleanup. it will be all fine after that.
dobbor1
Post by dobbor1 » Mon Feb 25, 2013 4:46 pm
Just the back off or do I need to remove the actual mirror itself?
jaynana
Post by jaynana » Mon Feb 25, 2013 4:52 pm
I didn't remove the mirror frame from the car. From memory (been a while now) the back cover, the surround and the reflector also come off, leabing the fame and the motors in a rubber glove sort of thing.
Easy enough to clean at this point and re-greese. That sorted it out and its been working since..
When removing the cover be careful not to break the clips that hold it in place.. Bit tricky as it was tight.
dobbor1
Post by dobbor1 » Mon Feb 25, 2013 5:13 pm
Excellent thanks for the advice.
