Hi ALL
Sorry for another ??? Having the issue with my battery keep failing and getting trans failsafe error showing, unable to start my car, think time change alternator belt as this may be the problem, any advice on the best belt one to buy.. should I change any thing else at the same time.. 38,000 miles, (4.4 2005) have change fuel filter HT leads, spark plugs.. just need to solve why I keep getting trans failsafe error..
Thank you very much
Andy..a
E53 4.4 2005 ALTENATOR BELT
Re: E53 4.4 2005 ALTENATOR BELT
Sounds to me likely you need a new battery, trans fail safe always pops up with low voltage normally caused by a failing battery, the belt is tensioned by a pulley tensioner so when its knackered it will basically break and not slip as they use to in the old days.
New battery fitted five months ago, second one in less 14months.. must be not the battery..
- sleepyfolk
Are you sure your starter motor is not pulling excess current and screwing your batteries? Was a well known issue with one brand of starter, I got a Bosch exchange unit from ECP for about £140 I think.
If you’re changing belts and you may as well - get Continental I was told - so I did!
Starter motor well worth a look. Very common issue in cars made around the time your was. Both my E53 and E46 from 2004/5 had to be done. I bought a Bosch one from ECP too.
You need to check voltages on the battery when running/charging and after it has been left overnight. It could be a power drain on the system.
