battery venting
Smeeagain
battery venting
Post by Smeeagain » Wed Dec 07, 2011 6:26 pm
I have seen conflicting advice on different post - some saying a vent/breather should be connected to the battery others state to plug the unused vent hole with the plug moulded into the terminal cover.
I am fitting Bosch Silver S5 100ah to a 2004 E53 X5 3.0 D Sport.
Can someone advise the correct proceedure please?
Smee
Sanj
Re: battery venting
Post by Sanj » Wed Dec 07, 2011 6:58 pm
Two vents either side of the battery ends. Plug the one at the negative end, vent the one at the positive end.
That's what I've done (besides that's the only option, battery won't fit the other way round and the vent pipe is at the positive end).
Re: battery venting
Post by X5Sport » Wed Dec 07, 2011 7:06 pm
Sanj's right. You must vent otherwise you will get a build up of Hydrogen and in the right ratio that goes Boom! Can bring a whole new meaning to the term sub-woooofffer
Sanj
Re: battery venting
Post by Sanj » Wed Dec 07, 2011 7:08 pm
:lol:
Think AW8 also said he had some perspiration in that boot area... Not an ideal mixture to be sweating!
AW8
Re: battery venting
Post by AW8 » Wed Dec 07, 2011 9:12 pm
I had one vent hole connected to the advacent vent pipe but I had failed to plug the other vent hole at the opposite end.
I since used the blanking plug supplied, (as moulded into the Bosch terminal cover), to block the terminal vent hole that does not attach to a pipe.
I hope that makes sense
x555
Re: battery venting
Post by x555 » Wed Dec 07, 2011 10:33 pm
No conflicting advise...as said above you need to do both. Vent one side and cap the other ;)
AW8
Re: battery venting
Post by AW8 » Thu Dec 08, 2011 12:27 am
Sorry thats what I meant - I have edited my last post above to make this clearer. :)
