AE LED Upgrade
jaynana
AE LED Upgrade
Post by jaynana » Wed Feb 27, 2013 8:19 pm
thought of finally doing the upgrade, now that they're working as DLRs.
i know this has been done many times. what model would you recommend pls?
1. HIDS-Direct
2. HIDS4U
3. Convert2Xenon
can go upto 10W... i know that its the colour temperature that is important. hids4u says their's is 7000K. others don't specify.
Also i believe its a straight swap. TIS shows as below. only one bulb per side for both AE rings? i thought there would be 2 bulbs/side - one for each ring?
thx
j
Sanj
Re: AE LED Upgrade
Post by Sanj » Wed Feb 27, 2013 8:43 pm
Piece of cake to change - one bulb/LED each side.
As for colour/temp/wattage, no idea!
Raj
Re: AE LED Upgrade
Post by Raj » Wed Feb 27, 2013 8:56 pm
They'll all be much the same tbh even the extra wattage ones. Not enough power hike to make a real visible difference. Changin is very straight forward and is one per side.
Re: AE LED Upgrade
Post by X5Sport » Wed Feb 27, 2013 9:16 pm
Most LEDs are well above 5,000K so it just depends whose LEDs they actually use.
As said, 5 min job.  One lamp as it uses a light pipe to get the rings lit.
jaynana
Re: AE LED Upgrade
Post by jaynana » Wed Feb 27, 2013 10:42 pm
thanks all,
its a done deal, hids direct, just did a google and picked up a 5% discount code as well.
these are supposedly CREE LEDs which i think are market leaders, 7000k, 10W.
j
graemeX5
Re: AE LED Upgrade
Post by graemeX5 » Fri Mar 01, 2013 1:16 pm
you may find when citing the power steering reservoir on n/side is a bit in the way best solution is to undo the 3 bolts makes access a lot easier.
Hth
jaynana
Re: AE LED Upgrade
Post by jaynana » Sat Mar 02, 2013 4:07 pm
simplest upgrade ever - just changing bulbs lol
not as bright as i expected tbh..
amazing even distribution throughout the rings with just one spot of a light source really..
Re: AE LED Upgrade
Post by X5Sport » Sat Mar 02, 2013 7:24 pm
As others have noted, they look great but the brightness needs to improve - which steadily over the years and new generations of LEDs it slowly is.
Raj
Re: AE LED Upgrade
Post by Raj » Sat Mar 02, 2013 11:31 pm
Always a nice upgrade.
