Battery drains when left a few days can I plug in a charger to keep topped up ?
Via the cigarette lighter socket ?
The jumping points on the car ?
Or removing the battery every time ?
Which chargers are the best to use ?
It is a 54 plate 3.0 d sport , changed the battery 6 months ago to Bosch 100 amp , is there something I can check that maybe draining battery as this seems to be a common problem ? Dealer says it is the starter but the battery change cured the problem only started now the weather has changed again !
Is it a common problem on the e70 model ?
Thanks in advance !
Battery drain which chargers ?
Re: Battery drain which chargers ?
Something like CTEK unit will do the job. You can connect it to the points under the bonnet (BMWs preferred location). It also has a battery conditioning function and can be left connected and running if you wish.
A few of us on here have one and the OEM charger is just a rebadged CTEK. I use mine to keep the stored E46 battery in good nick.
Hi thanks do you have a model no ? & where is the best place to buy ?
There's a link in my reply to an appropriate model....
. Click the first CTEK.
Hi sorry didn't see that ! Bmw direct have them £74.95 free delivery & 10 percent off that price so nearly the same cost .
Sometimes there are some good deals, especially at this time of year. :xmasgrin:
