Aero Wiper Blades
Aero Wiper Blades
I bought some aero wiper blades from fleabay but the longer 24" blade (drivers) loses contact in the middle, the 22" and rear work great, also bought a set for my Boxster and they work superbly. The seller did send me a replacement but same problem.
So I'd still like aero style blade can anyone recommend ones they are using and know work well please.
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
Aero Wiper Blades
I have just got the same from eBay for X5 and the discovery and exactly the same. All 3 on disco fine, rear and passenger on X fine but drivers side leaves middle bit unwiped. He is sending out another set for the X but don't think it will work. I'm wondering if it's to do with the little stabiliser bracket on the arm. They should have thought about this though if it is a problem
May try Bosch next. Other thing is the fixing point bracket is huge!
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Re: Aero Wiper Blades
Is it a case of 'tweaking' the wiper arm slightly to alter the angles and see if that works?
Aero Wiper Blades
i think the spring on the OEM arm not strong enough to push the aero blades down on the windscreen. i had the same issue and tossed them away and got bosch ones from eurocarparts for £6 each
Sent from my iPhone 4S using Tapatalk
Aero Wiper Blades
[quote=""X5Driver""]I have just got the same from eBay for X5 and the discovery and exactly the same. All 3 on disco fine, rear and passenger on X fine but drivers side leaves middle bit unwiped. He is sending out another set for the X but don't think it will work. I'm wondering if it's to do with the little stabiliser bracket on the arm. They should have thought about this though if it is a problem
May try Bosch next. Other thing is the fixing point bracket is huge![/quote]
identical my replacement never worked either.
Aero Wiper Blades
Is that standard bosch or aero for £6 from ecp?
Aero Wiper Blades
[quote=""X5Driver""]Is that standard bosch or aero for £6 from ecp?[/quote]
yeah same question, linky please
Aero Wiper Blades
standard bosh . i bought a few parts together and used a %25 off but originally it was around £8.
Aero Wiper Blades
There is a little plastic guide on the wiper arm about half way down that you have to cut about 10mm off it then clears the wiper and stops it lifting
It worked on mine when I had the same problem
2015 Space grey 30d F15
Aero Wiper Blades
That little plastic guide pulls off to leave an even smaller metal tang. It just looks wrong on my beautiful X. Probably Chinese wipers so designed for that X lookalikey off topgear where they wouldn't give a stuff about my little tang phobia
Aero Wiper Blades
This is the guide just cut about 10mm off the end with a pair of side cutters
Hope this helps
Hope this helps
Aero Wiper Blades
I 'removed' this too and they work perfectly, best wipers I've ever had ! God I need to get out more.........
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Current Bikes:
GSX-R1000k6 (His)
I've got bosch aero flatblades and never had a non-contact problem.
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
Aero Wiper Blades
[quote=""B5tew""]This is the guide just cut about 10mm off the end with a pair of side cutters
Hope this helps
Sent from my iPhone using Tapatalk[/quote]
are these aero flat blades as mine does not have this, it's quite literally just the rubber blade.
Think I may just bite the bullet and order the Bosch ones.
Hope this helps
Aero Wiper Blades
The plastic guide is on the existing wiper arm on your car and because the aero wipers have a lower profile it touches the blade as the wiper moves across the screen and lifts the centre of the wiper
At least that was what was happening on my car
