Aero Wiper Blades
jeegnesh
Aero Wiper Blades
Post by jeegnesh » Sat Jun 02, 2012 10:46 am
I bought some aero wiper blades from fleabay but the longer 24" blade (drivers) loses contact in the middle, the 22" and rear work great, also bought a set for my Boxster and they work superbly. The seller did send me a replacement but same problem.
So I'd still like aero style blade can anyone recommend ones they are using and know work well please.
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
X5Driver
Aero Wiper Blades
Post by X5Driver » Sat Jun 02, 2012 11:08 am
I have just got the same from eBay for X5 and the discovery and exactly the same. All 3 on disco fine, rear and passenger on X fine but drivers side leaves middle bit unwiped. He is sending out another set for the X but don't think it will work. I'm wondering if it's to do with the little stabiliser bracket on the arm. They should have thought about this though if it is a problem
May try Bosch next. Other thing is the fixing point bracket is huge!
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Re: Aero Wiper Blades
Post by X5Sport » Sat Jun 02, 2012 11:10 am
Is it a case of 'tweaking' the wiper arm slightly to alter the angles and see if that works?
kkodal78
Aero Wiper Blades
Post by kkodal78 » Sat Jun 02, 2012 11:28 am
i think the spring on the OEM arm not strong enough to push the aero blades down on the windscreen. i had the same issue and tossed them away and got bosch ones from eurocarparts for £6 each
Sent from my iPhone 4S using Tapatalk
jeegnesh
Aero Wiper Blades
Post by jeegnesh » Sat Jun 02, 2012 11:30 am
[quote=""X5Driver""]I have just got the same from eBay for X5 and the discovery and exactly the same. All 3 on disco fine, rear and passenger on X fine but drivers side leaves middle bit unwiped. He is sending out another set for the X but don't think it will work. I'm wondering if it's to do with the little stabiliser bracket on the arm. They should have thought about this though if it is a problem
May try Bosch next. Other thing is the fixing point bracket is huge![/quote]
identical my replacement never worked either.
X5Driver
Aero Wiper Blades
Post by X5Driver » Sat Jun 02, 2012 11:32 am
Is that standard bosch or aero for £6 from ecp?
jeegnesh
Aero Wiper Blades
Post by jeegnesh » Sat Jun 02, 2012 11:33 am
[quote=""X5Driver""]Is that standard bosch or aero for £6 from ecp?[/quote]
yeah same question, linky please
kkodal78
Aero Wiper Blades
Post by kkodal78 » Sat Jun 02, 2012 11:46 am
standard bosh . i bought a few parts together and used a %25 off but originally it was around £8.
B5tew
Aero Wiper Blades
Post by B5tew » Sat Jun 02, 2012 12:07 pm
There is a little plastic guide on the wiper arm about half way down that you have to cut about 10mm off it then clears the wiper and stops it lifting
It worked on mine when I had the same problem
2015 Space grey 30d F15
X5Driver
Aero Wiper Blades
Post by X5Driver » Sat Jun 02, 2012 12:11 pm
That little plastic guide pulls off to leave an even smaller metal tang. It just looks wrong on my beautiful X. Probably Chinese wipers so designed for that X lookalikey off topgear where they wouldn't give a stuff about my little tang phobia
B5tew
Aero Wiper Blades
Post by B5tew » Sat Jun 02, 2012 12:11 pm
This is the guide just cut about 10mm off the end with a pair of side cutters
Hope this helps
ianmaney
Aero Wiper Blades
Post by ianmaney » Sat Jun 02, 2012 3:47 pm
I 'removed' this too and they work perfectly, best wipers I've ever had ! God I need to get out more.........
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
n1k85
Post by n1k85 » Sat Jun 02, 2012 7:02 pm
I've got bosch aero flatblades and never had a non-contact problem.
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
jeegnesh
Aero Wiper Blades
Post by jeegnesh » Sun Jun 03, 2012 5:01 pm
[quote=""B5tew""]This is the guide just cut about 10mm off the end with a pair of side cutters
Hope this helps
Sent from my iPhone using Tapatalk[/quote]
are these aero flat blades as mine does not have this, it's quite literally just the rubber blade.
Think I may just bite the bullet and order the Bosch ones.
B5tew
Aero Wiper Blades
Post by B5tew » Sun Jun 03, 2012 9:18 pm
The plastic guide is on the existing wiper arm on your car and because the aero wipers have a lower profile it touches the blade as the wiper moves across the screen and lifts the centre of the wiper
At least that was what was happening on my car
